Building a new system and need advice
  • Building a new system and need advice
    Hi Everyone,
    I am wanting to build a system based on the ASUS E45M1-M Pro motherboard (http://www.asus.com/Motherboards/AMD...rd/E45M1M_PRO/). According to the memory specifications for the motherboard the board supports the following:
    2 x DIMM, Max. 8GB, DDR3 1600(O.C.)/1333/1066 MHz Non-ECC, Un-buffered Memory
    Single Channel Memory Architecture
    When I check the vendors list this board is lined to the list doesnt really make any sense as it has lists for memory configurations that could not possibly fit this board (such as six memory stick configs for 12 gig etc...).
    What I would like to know is what are my available options for fitting the board with 8Gig of RAM? Can this be done with DDR3 1600?
    It has been so long since I built a system that I am finding myself a little lost with all the options available and any help that can be brought to bear on this would be most appreciated.
    Kind Regards
    The Frog
    ASUS 'tests' their mobos with whatever is available, DRAM wise, so if a 4 or 6 stick set is available they pop in (in this case) 2 sticks of the set. If going for 8GB, think I'd go on the safe side and prob try a set of 1333 sticks in 1.5 volt
      These are what I can see as options so far.....
      DDR 1600 : F3-12800CL9D-8GBRL
      DDR 1333 : F3-10666CL7D-8GBRH
      There is nothing listed at 1066 from G.Skill in the Asus approved vendor list. Both of the ones listed above seem to operate at 1.5 volt, with the 1333 having a lower latency, but then 1600 should probably be faster right? Is it even going to make a hoot of difference? My primary concern is to have the machine stable and that is all. I dont want to have to play with the settinsg 'too much' - that is to say I have no intention of performing massive overclocking on this machine. Faster ram would be nice if the machine can handle it without too much hassle. Would either of the kits listed above do the job? I am thinking the second one based on what you have said.
      Cheers
      The Frog
        Actually the 1333 @ CL7 prob out perform the 1600 @ CL9.......Normally 1333 at CL8 ir roughly equivalent to 1600 @ CL9, so the 7 may give it an edge, performance wise, might even be able to run the 1333/7 sticks at 1600/8
          Thats what I was looking to know
          Thankyou very much Tman, thats great info and exactly what I needed to know. I really appreciate the help and guidance. Time to go and order me a new toy to play with.......
          Many, many thanks
          The Frog
            Let us know how it goes
              One happy camper
              Hi again,
              Thankyou for the great advice. The new pc I built is flying along very nicely and is rock stable. That memory kit (1333 @ CL7) works perfectly and is a perfect companion for the motherboard. Extremely cost effective too!
              Cheers ant thanks
              The Frog
                Great, glad to hear it, will e-mail you a bill............just kidding, have a gud 1!
