HI,
I've just purchased a 2x4Gb kit (matched sticks) of RipJawsX CL 7-8-7-24 1.6V RAM (F3-12800CL7D-8GBXH) along with a new Gigabyte Z68X UD7 and i2500k and am currently running win 7 64, updated BIOS and drivers.
I am trying to determine if either my RAM or my motherboard is faulty or at least understand what is going on. I can boot fine with the RAM, no trouble posting or installing windows, but when I ran memtest to start testing the RAM the day i got my board, it failed in seconds (dual channel at rated timings/voltage).
I started testing more and more to see what was wrong. At the default timings (11-11-11-28, 1.5V) memetest runs fine in dual channel, I have also run memtest on each stick separately; each stick is 9 hours plus error free when tested alone at the same timings.
The odd thing, is that whenever either all of the second channel or a single dimm of the second channel is populated, memtest reports timings of 6-6-6-20 and NOT what they are currently set at in the BIOS (either default or rated timings since I've tried both). But in dual channel, memtest does accurately report the timings that I have set.
The other thing is that memtest seems to always report the speed at 712 MHz (DDR3 1424) when I've always been running at 1600 as set in the BIOS and confirmed by CPU-Z.
I am by no means an expert but want to figure out what, if anything, is wrong so I am not stuck with less than 100% working components.
