F3-12800CL9T-12GBRL and Rampage 3 Formula
  • F3-12800CL9T-12GBRL and Rampage 3 Formula
    Hey there, I have just finished building my computer. I have a rampage 3 formula with an intel core i7 960. I purchased the F3-12800CL9T-12GBRL kit and the timings are rated at 1600. When I go to the bios they are set to 1066. So to get the 1600 timings I set the profile to X.M.P. Once I do this I can never get the computer to boot. It just says overclocking failed.
    Things I have tried:
    1.) Set X.M.P. (failed)
    2.) Set speed and timings manually (failed)
    3.) Set DRAM Bus Voltage to 1.64 (failed)
    I did test each stick individually and none of them were stable at 1600. I can only get them to 1333.
    Is there any safe way to get them at there rated speeds or do I have to RMA them?
    Fast reply would be greatly appreciated thanks!
    Try manual settings. Are you using the latest version BIOS?
    Manually set DRAM Frequency, timings, and voltage in BIOS.
      thank you very much, Had a feeling it was because of the BIOS. Once i got a chance to do that I did. Everything is running nice and tight. LOVE G SKILL!!!!
        Glad to hear it, Enjoy!
