I assembled a HTPC but I'm encountering random BSODs that always have something to do with memory, like "memory management".
This is my config:
Motherboard: Gigabyte GA-H67MA-UD2H-B3 (1.1) - QVL
CPU: Intel Core i3 2100
RAM: G.Skill Ripjaws X F3-12800CL9D-4GBXL
OS: Windows 7 64bit
I ran Memtest86+ for a few hours without any errors. Running Orthos under windows however, gives me an error after a few seconds.
Everything in BIOS is set to "auto". Unfortunately I can't enable XMP, I suspect my cpu doesn't support it. I saw tRAS was automatically set to 28 so I changed it to 24, but all problems remained.
Any advice?
This is my config:
OS: Windows 7 64bit
Code:
Beginning a continuous self-test to check your computer. Press Stop to end this test. Test 1, 4000 Lucas-Lehmer iterations of M19922945 using 1024K FFT length. FATAL ERROR: Rounding was 0.497.., expected less than 0.4 Hardware failure detected, consult stress.txt file. Torture Test ran 0 minutes 04 seconds - 1 errors, 0 warnings. Execution halted.
Any advice?
