I assembled a mini pc with:
Asrock A330 ION mobo with Nvidia MCP7A-ION Chipset
G.SKill F3-8500CL7D-2GBNQ ( 1GBx2 ) RAM
So I've got two identical modules of G.Skill F3-8500CL7D-2GBNQ RAM for a total amount of 2 GB of RAM (every module is 1 GB).
Now, the problem is that if I boot with both modules (my bios says "dual channel memory") I get errors and can't boot in my OS. So I have to turn off my pc using the power button: After that I can power on the pc and everything works fine, up to the next "cold boot".
In fact this kind of problem present itself just when I'm doing a cold boot, which means to power on my pc after some hours that it is switched off.
Initially I thought it was an hardware problem concerning my motherboard, but then I figured out that if I use just one module of Ram the boot is fine and there's no problem at all.
I tried the single Ram boot (one moduel at the time) with both the modules (also exchanging the DIMM slots) and everything is working properly so I thought my Ram and MoBo could be ok.
But I can't figure out why I cannot use both the modules at once:
Is there some special bios configuration to apply? Could my motherboard not support Dual Channel Memory? Or is this and hardware problem (e.g broken motherboard)?
Thank you in advice for your reply.
