XMP is only for a single kit, it will not work properly when multiple kits are used.
Overclockers use the i7 at the minimum, they also have Extreme Series CPUs that is technically what should be used.
BUT, you can attempt it with your i5 760. Some good chips are capable of BCLK 213+, so make it to 200 first, then work your way up to see what you and your chip can do. Hopefully you have a lot of patience.
At least we'll be here to help..
If you'd like, find the max BCLK and that will give you a better idea of what the chip may be capable of.
http://www.masterslair.com/361/deter...ency-i7-i5-i3/
Keep us posted!
Keep us posted!
