register
First believe the 775 Rampage Extreme had an 8GB limit on DDR3, which was 4x2GB, it ran the X48 chipset which took the MC (North Bridge) almost exact from the X38......let me check if I've got anything on it
I've had no issues in bios or win7x64 recognizing or utilizing the amount of RAM on the board properly. I have just never been able to get it to post with the RAM operating with a FSB of 800Mhz.
Assuming you mean frequency of 800 for the DRAM, the FSB is a default of 1333 and can run 1600 as an OC....if it sees the 16GB would say you'll need more NB voltage, prob need the DRAM about 1.55 to 1.6 and depending on your CPU may need to raise the vCore (there's a number of socket 775 Quad cores)
I haven't raised the voltage that high yet due to inexperienced apprehension. Never got too far into overclocking. I'll give that a shot and see if it posts.
I played with the voltage a bit last night and got it to post a few times. Windows pooped all over itself after that so I did a recovery and went to bed.
When I run all my bios settings at default (1333), I have no stability issues. When I bump the RAM up to 1600 it won't post until I up the voltage to 1.6. I'll try upping the NB a bit as well. I haven't touched it as I don't know what it does (I'm assuming it ups the voltage for the North Bridge).
I upped the mV to the North bridge by +50mV (not sure if I should be going higher) while having DRAM voltage set to 1.6V. Everything seems to Post, but windows still likes to die in a fire giving me either a Bluescreen or a message about a checksum for a file failing.
I've tried running the RAM in auto settings and manual settings:
CAS# Latency - 9
RAS# to CAS# - 9
RAS# Pre - 9
tRAS - 25
tRC - 38 (Bios doesn't have an option for 40, apparently)
Command Rate - 2N (Which I can only assume is the same as 2T because that's what's in BIOS under Command Rate)
Is there something possibly wrong with my manual settings?
