Hi, I am in need of help with my new setup
I am using a
P8H67-v B3 rev motherboard
i5-2500k
2 x 4GB G.Skill RipJaws X (F3-12800CL9D-8GBXL)
WD 500GB HDD
My problem.
I have no problem running the machine with one stick of the 4GB installed, but when I add the seconde, It sometimes starts up and then after a phew seconds switches back off and cycles. then other times it starts up and recognises the memory in the bios and boots. then when it gets to "windows starting" it hangs and restarts.
I then remove the second stick and all is well again.
It's really annoying me now.
Any help you could give would be great.
I have ready many threads on it but I don't think my problem is the same.
Cheers
Jonburf
I am using a
i5-2500k
WD 500GB HDD
My problem.
Cheers
Jonburf
