I have a brand-new build on the MB GIGABYTE|GA-Z68X-UD7-B3.? ? 2600K watercooled.
At present I am running the memory F3-17600CL9D-8GBXLD as follows: ?
memory clock: 936 MHz
memory speed: DDR 3-1872
DRAM: FSB 28:3
memory timing: 9-11-9-28 CR 2
rest of the memory timings settings are set to AUTO
DIMM voltage: 1.64 V
VTT voltage: 1.2 V
If I set the memory clock any higher the computer refuses to boot. On the other hand, at this speed I have run memtest overnight with no errors and LinX(50 runs) and prime (five hours). The PC has a stable overclock at 4.7 MHz. C-1/C6 enabled.
Can you please suggest how I can loosen the timings to attempt to reach the next speed level for this memory. Obviously any suggestions on voltage settings would be greatly appreciated.
DRAM: FSB 28:3
VTT voltage: 1.2 V
