I'm using following motherboard
ASRock 760GM-GS3
http://www.newegg.com/Product/Produc...82E16813157215
With a AMD Phenom II x2 CPU (HDZ555WFGMBOX)
http://www.newegg.com/Product/Produc...82E16819103846
and
GSkill 4gb (2x2gb) F3-10666CL8D-4GBHK
http://www.newegg.com/Product/Produc...82E16820231189
everything posts great, I can boot from my UBCD and do CPU burn in and I've done Memtest 86+ with no errors after 24 hours.
However, I cannot boot to anything other than UBCD. If I try to install Windows 7 I either get lockups or screen freezes.
Ideally I'd like to unlock all the cores on the CPU and even overclock it by 5 to 10% - which I've done and have had no issues in burn-in.
However I'm still not able to load any OS. I've tried Win7 64, WinXP and Ubuntu 10.
I've tried this memory with manual settings of
1.5v on 9-9-9-24 as well as 8-8-8-21
I've tried various combinations of tweaks including upping the voltage to 1.5 and 1.6
I've tried turning off all OC options and leaving everything at auto
memory is detected at
DRAM Voltage - 1.5v
Memory controller Model - unganged
Power down enable - disabled
Bank Interleaving - auto
channel Interleaving - hash 2
CAS latency - 9
TRCD - 9
TRP - 9
TRAS - 24
TRTP - 5
TRRD - 4
TWTR - 5
TWR - 10
TRC - 33
TRWTWB - 8
TRWTTO - 7
TWRRD - 2
TWRWR - 3
TRDRD - 3
TRFC0 - 110
MA Timing - 1
CHA ADDR/CMD Delay - 22/64
CHA ADDR/CMD Setup - 1
ChA CS/ODT Delay - 0
CHA CS/ODT Setup - 1/2
CHB ADDR/CMD Delay 22/64
CHB ADDR/CMD Setup 1
CHB CS/ODT Delay 0
CHB CS/ODT Setup 1/2
CHA CKE Drive - 1.50x
CHA CS/ODT Drive - 1.50x
CHA ADDR/CMD Drive - 1.5x
CHA CLK Drive - 1.50x
CHA DATA Drive - 1.00x
CHA DQS Drive - 1.00x
CHA Processor ODT - 60 Ohms
CHB CKE Drive - 1.50x
CHB CS/ODT Drive - 1.50x
CHB ADDR/CMD Drive - 1.50x
CHB CLK Drive - 1.50x
CHB DATA Drive - 1.00x
CHB DQS DRIVE - 1.00x
CHB Processor ODT - 60 ohms
So... boot issues persist with the auto settings and so far with the minor tweaking I've tried so far. Given the random nature of the errors (different BS errors, general memory exceptions or just locking up during the setup process depending on the setting) I'm pretty certain if I can just find the right settings it will all be good.
RAM and CPU test and burn in great, tried 3 different hard drives, tried multiple different versions of each install disk and USB installers for Win7 and Ubuntu.
Reading over this forum, Gskill Tech really knows his stuff (this is coming from a 15 year IT help Desk operations guru) so I have high hopes I'll get some good answers here.
So... doing a bad imitation of a Princess Leia recording on an astromech Droid... "Help me Gskill Tech, your my only hope!"
ASRock 760GM-GS3
and
DRAM Voltage - 1.5v
CAS latency - 9
TRCD - 9
TRP - 9
TRAS - 24
TRTP - 5
TRRD - 4
TWTR - 5
TWR - 10
TRC - 33
TRWTWB - 8
TRWTTO - 7
TWRRD - 2
TWRWR - 3
TRDRD - 3
TRFC0 - 110
MA Timing - 1
CHB CS/ODT Delay 0
