F3-10666CL7D-4GBRH + P7P55d-e lx + i5 760
  • F3-10666CL7D-4GBRH + P7P55d-e lx + i5 760
    I'm having major issues on getting this to work properly. I just built a computer today that wont stop freezing. I have Windows 7 64-bit installed and all the drivers. But underload, even if its just installing something and I press the start button, the computer freezes. After I installed some updates, I had to restart the computer and then it wouldnt stop saying "shutting down". Eventually the blue screen of death came up and then it restarted. What is going on? I cant figure out what is wrong.
    Specs:
    Windows 7 64-bit
    ASUS P7P55D-E LX LGA 1156
    Intel Core i5-760 Lynnfield 2.8GHz
    G.SKILL Ripjaws Series 4GB (2 X 2gb) model F3-12800CL9D-4GBRL
    EVGA GeForce GTX 570 Fermi
    Here is a album of pics I took of the BIOS and BSOD.
    http://alphabet85.imgur.com/computer_problems#GOR2h
    Also I really don't know much about how to edit things in BIOS. I don't know what any of the timing and volts mean.
      For AI Overclock Tuner option in BIOS, set that to XMP Profile.
      What's up with different model memory in title and actual post? haha
        Haha whoops. The one in the post was the one I was looking at to replace the F3-12800CL9D-4GBRL.
        I'll try that setting. Should I change anything else off of Auto?
          Should not need to, the XMP adjusts everything for you.
            I put in XMP and I was able to install windows. But when I went to update windows this happened...and its stuck. I can move the mouse around, but once I click anything it full on freezes. heres the link if picture doesnt show http://imgur.com/yGoqW
              Power down and restart, and then try it again
                K. I'll try just updating and restarting. But why does the disk always just stop and all the processes just disappear like that? Its like the somewhere between the HDD and the CPU data is lost and all is completely dropped.
                  Test each module, it may also be a HDD problem.
