so i finally built my own pc for the first time
i bought 2 4GB G.Skill Ripjaw Series DDR3 1600 cards and I heard to get the best performance from them i need to have them a dual channel setup (which on my board channel A is the 2nd and 4th slot)
the problem is, that when i have this set up (cards on slot 2 and 4) my computer wont boot, i turn it on, it will shut off after about 2-3 seconds, restart, then shut off,
its basically looped, keeps on doing that over and over, but it works fine when i have them on slot 3 & 4, my computer recognizes them fine
i have updated(flashed) the bios to the latest version and that didn't help
My Rig Is
Gigabyte GA-Z68XP-UD3P
2x 4GB G.Skill Ripjaw Series DDR3 1600 Memory
Intel i5 2500k Sandy-bridge CPU (cooled with a Corsair H60 Hydro Cooler)
EVGA GTX 560 GPU
Cooler Master GX 650w PSU
and if it matters, the case is a Azza Solano 1000R
My Rig Is
EVGA GTX 560 GPU
