Motherboard: ASUS P8Z68 DELUXE === BIOS v0706 - [Newest]
Processor: INTEL CORE I7-2600K
Heatsink: NOCTUA NH-D14
Memory: G.SKILL RIPJAWS 8GB 2X4GB DDR3-1600 [F3-12800CL7D-8GSR]
Video Cards: ASUS GeForce GTX 580
OS: Windows 7 64bit Enterprise === SP1 & All Windows Updates
i am unable to use a second stick on my motherboard....
if i put one stick of 4gb in soscket 2 (blue) on my motherboard the system boots with not any problem and i can see 4 gb in my sistem and all is ok...when i put the second stick in the socket 4 (blue) the motherboard flashes red and gives me q-code 2e and does not boot.
i thought was that second stick that was broken or had problem but it is not so... if i put in in slot 2 the system boots...so all the two sticks are "ok".
well i thought it was socket 4 that had problems and put in in socket 1 or 3.... the systems gives the same problem, not boots red light and q code. 2e
in other words a single stick in slot 2 the system goes well, when i put the other stick in any other slot the mainboard does not boot...
i tried with bios 501, 603 and newest 706, same problem, tried with all options in bios and with the asus memory buttom on mainboard, the motherboard doesn't boot...
as just i use one stick in slot 2 all is ok, when i put another stick doesn't boot.
any suggestion?
any suggestion?
