X58a-ud3r r2.0 f3-12800cl9d-8gbxl
  • X58a-ud3r r2.0 f3-12800cl9d-8gbxl
    Hello, I have had a ongoing problem when I run my gskill F3-12800CLD-8GBXL at its specified speed of 1600 the PC crashes causing the screen to either blue screen or just freeze whenever I'm running a game. If the ram is running at a speed of 1333 there is no issue and the pc runs fine.
    Can I find out the settings required to run this ram at its designed speed on this motherboard (X58A-UD3R) it's running the FE bios and is not overclocked.
    The CPU is A I7 970
    Not sure what CPU you have but if the sticks are set to spec timings and voltage, you'll want CR (Command Rate) at 2T (or 2N if using the N designator) and may want to raise the QPI/VTT Voltage about .04
      updated first post with CPU, sorry.
        You'll want the latest BIOS, FH1, which can be found here:
        http://www.gigabyte.us/products/prod...?pid=3449#bios
        from there you should just be able to enable XMP and select the profile for 1600
