Once GSkill gets the package the return normally is out within a couple of days, so it would be whatever the mail/travel time is.
Random reboot and crash
Shipping to Canada will take the longest. I'd say around 2 weeks, definitely not 3-5 months.
If you are interested in the 16GB kit, make sure to ask the RMA dept. if it is feasible and whether there is an upgrade fee. Make sure to let them know so they can make the proper adjustments on file, otherwise you will get the same as what you sent in.
Is this the right email for the RMA dept. rma@gskillusa.com? Its been 18 hours and theres no response.
Edit: Received email message in 3 hours after this post.Last edited by OCeaN; 08-10-2011, 04:09 PM.=My System=
Core i5 2500K
MSI P67A-GD53 w/ v1.14 (1.E)
MSI GTX570
GSkill Ripjaws X (2X4GB) 1600MHz
Corsair F40, Black 1TB, Blue 640GB
LG Burner
Corsair HX750 750W
Modded Antec 300
Noctua NH-U12P SE2
I tested these ram on my other system (LGA775) just to confirm and the issue definitely exist, random shutdown while gaming and boot cycle with anything over 1600 regardless of timings. I'll start the RMA process once I buy another kit.
=My System=
Core i5 2500K
MSI GTX570
LG Burner
Corsair HX750 750W
Modded Antec 300
Noctua NH-U12P SE2
Ok I bought another F3-12800CL9D-8GBXL just before I prepare to send my current ones off and I noticed something different. The kit I bought has a shiny silver, hologram GSKILL sticker with the date (2011Aug) stamped half way on it were my current ram just has the date (2011Mar) and GSKILL in red, no fancy sticker. The major change I noticed is that the timings table has changed in CPUZ and without XMP, the default timings are now 10-10-10-27 @ 1600 instead of 9-9-9-28 @ 1600.
My question is will the replacement ram be the same as what I have bought or sent? I am worried having two kits made 6 months apart will increase the odds of incompatibility.
Edit: Picture added for clarifications. The old and new kit works together but still crash from the current faulty ram. The one I bought is all good.
Core i5 2500K
MSI GTX570
LG Burner
Corsair HX750 750W
Modded Antec 300
Noctua NH-U12P SE2
