Very frequent bsods with F3-10600CL9D-8GBNT
  • Very frequent bsods with F3-10600CL9D-8GBNT
    I have 8 gigs of F3-10600CL9D-8GBNT RAM. I don't know all that much about computers, at least by the standards of this forum, so here's the full description:
    G.SKILL Value Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10600) Desktop Memory Model F3-10600CL9D-8GBNT
    I'm running it on this motherboard:
    ASRock H61M/U3S3 LGA 1155 Intel H61 HDMI SATA 6Gb/s USB 3.0 Micro ATX Intel Motherboard
    with this CPU
    Intel Core i3-2100 3.1GHz Dual-Core 65W LGA1155
    and this video card
    EVGA 01G-P3-1556-KR GeForce GTX 550 Ti (Fermi) FPB 1GB 192-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
    I get frequent bsods. I've appended the WhoCrashed logs to this message, below.
    I've just tried changing the voltage from "auto" to 1.605 or something like that. It had been set at around 1.575, I think.
    Do you have any ideas? I'm not trying to overlock this computer or anything. I just want to get it working at spec. It mostly works okay, but it crashes pretty frequently. No obvious pattern; sometimes while watching YouTube, sometimes while playing LOL.
    crash logs 1
    crash logs
    windows version: Windows 7 Service Pack 1, 6.1, build: 7601
    windows dir: C:\Windows
    CPU: GenuineIntel Intel(R) Core(TM) i3-2100 CPU @ 3.10GHz Intel586, level: 6
    4 logical processors, active mask: 15
    RAM: 8571781120 total
    VM: 2147352576, free: 1948942336
    Crash Dump Analysis
    Crash dump directory: C:\Windows\Minidump
    Crash dumps are enabled on your computer.
    On Sun 7/24/2011 4:11:55 AM GMT your computer crashed
    crash dump file: C:\Windows\Minidump\072311-21606-01.dmp
    This was probably caused by the following module: ntoskrnl.exe (nt+0x7FD00)
    Bugcheck code: 0x1A (0x411, 0xFFFFF680000068A8, 0x5C00, 0xFFFFF68000000003)
    Error: MEMORY_MANAGEMENT
    file path: C:\Windows\system32\ntoskrnl.exe
    product: Microsoft? Windows? Operating System
    company: Microsoft Corporation
    description: NT Kernel & System
    Bug check description: This indicates that a severe memory management error occurred.
    This might be a case of memory corruption. More often memory corruption happens because of software errors in buggy drivers, not because of faulty RAM modules.
    The crash took place in the Windows kernel. Possibly this problem is caused by another driver which cannot be identified at this time.
    crash dump file: C:\Windows\memory.dmp
    This was probably caused by the following module: ntkrnlmp.exe (nt!KeBugCheckEx+0x0)
    On Fri 7/22/2011 6:53:01 AM GMT your computer crashed
    crash dump file: C:\Windows\Minidump\072111-21886-01.dmp
    Bugcheck code: 0x4E (0x99, 0x16BE17, 0x3, 0x182278)
    Error: PFN_LIST_CORRUPT
    Bug check description: This indicates that the page frame number (PFN) list is corrupted.
    This appears to be a typical software driver bug and is not likely to be caused by a hardware problem. This might be a case of memory corruption. More often memory corruption happens because of software errors in buggy drivers, not because of faulty RAM modules.
    On Mon 7/18/2011 2:39:01 AM GMT your computer crashed
    crash dump file: C:\Windows\Minidump\071711-24180-01.dmp
    Bugcheck code: 0x1A (0x41790, 0xFFFFFA8003140100, 0xFFFF, 0x0)
    On Sun 7/17/2011 1:43:27 AM GMT your computer crashed
    crash dump file: C:\Windows\Minidump\071611-21309-01.dmp
    Bugcheck code: 0x19 (0x3, 0xFFFFF88002187550, 0xFFFFF88002182150, 0xFFFFF88002187550)
    Error: BAD_POOL_HEADER
    Bug check description: This indicates that a pool header is corrupt.
    On Thu 7/14/2011 1:38:25 PM GMT your computer crashed
    crash dump file: C:\Windows\Minidump\071411-23727-01.dmp
    Bugcheck code: 0x1A (0x41284, 0xFFFFF7063FBE6001, 0x196133, 0xFFFFF70001080000)
    On Thu 7/14/2011 10:53:42 AM GMT your computer crashed
    crash dump file: C:\Windows\Minidump\071411-23758-01.dmp
    Bugcheck code: 0x1A (0x41284, 0xFFFFF8A009F44001, 0x9971, 0xFFFFF781C0000000)
    On Sun 7/10/2011 3:33:53 AM GMT your computer crashed
    crash dump file: C:\Windows\Minidump\070911-33399-01.dmp
    Bugcheck code: 0x1A (0x411, 0xFFFFF683FF7F7E00, 0x4C00, 0xFFFFF68000000003)
    On Sun 7/10/2011 2:36:15 AM GMT your computer crashed
    crash dump file: C:\Windows\Minidump\070911-29530-01.dmp
    Bugcheck code: 0x19 (0x3, 0xFFFFF8A007E03620, 0xFFFFF8A007E03620, 0xFFFFF8A007E02620)
      crash logs 2
      On Sat 7/2/2011 9:00:54 PM GMT your computer crashed
      crash dump file: C:\Windows\Minidump\070211-34647-01.dmp
      On Sat 7/2/2011 6:33:46 PM GMT your computer crashed
      crash dump file: C:\Windows\Minidump\070211-27159-01.dmp
      Bugcheck code: 0xA (0x0, 0x2, 0x0, 0xFFFFF80002C7A904)
      Error: IRQL_NOT_LESS_OR_EQUAL
      Bug check description: This indicates that Microsoft Windows or a kernel-mode driver accessed paged memory at DISPATCH_LEVEL or above.
      On Sat 7/2/2011 7:15:32 AM GMT your computer crashed
      crash dump file: C:\Windows\Minidump\070211-20202-01.dmp
      This was probably caused by the following module: dxgkrnl.sys (dxgkrnl+0x849E)
      Bugcheck code: 0x1A (0x5003, 0xFFFFF70001080000, 0x4A8E, 0x4A9000008D1C)
      file path: C:\Windows\system32\drivers\dxgkrnl.sys
      description: DirectX Graphics Kernel
      The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system which cannot be identified at this time.
      On Mon 6/27/2011 12:21:10 AM GMT your computer crashed
      crash dump file: C:\Windows\Minidump\062611-15990-01.dmp
      Bugcheck code: 0x3B (0xC0000005, 0xFFFFF8000291AB2C, 0xFFFFF88003765E50, 0x0)
      Error: SYSTEM_SERVICE_EXCEPTION
      Bug check description: This indicates that an exception happened while executing a routine that transitions from non-privileged code to privileged code.
      On Sun 6/26/2011 11:12:00 PM GMT your computer crashed
      crash dump file: C:\Windows\Minidump\062611-24086-01.dmp
      Bugcheck code: 0x1A (0x41790, 0xFFFFFA8003140130, 0xFFFF, 0x0)
        Do you have the latest BIOS? Have you tried running memtest on each stick individually to make sure both sticks are good
          Hi -
          I did update the BIOS. It's still doing it. Here are some new reports:
          VM: 2147352576, free: 1948221440
          Crash Dump Analysis
          On Sat 8/6/2011 10:19:14 PM GMT your computer crashed
          crash dump file: C:\Windows\Minidump\080611-29515-01.dmp
          Bugcheck code: 0x1A (0x5003, 0xFFFFF70001080000, 0x49E, 0x4A000000D3C)
          On Wed 8/3/2011 3:05:00 AM GMT your computer crashed
          crash dump file: C:\Windows\Minidump\080211-47205-01.dmp
            Have you run memtest on each stick individually? Also can you post your DRAM settings as well as your system voltages
              Thanks for the reply!
              I googled around, but can't figure out how to get that info. Any suggestions?
                Start with Memtest, can get it here and instructions on how to run it
                http://www.memtest.org/
                  Got my settings:
                  VOLTAGE
                  Power Saving || Disabled
                  CPU Core Voltage Offset || +0mV
                  IGPU Voltage Offset || +0mV
                  DRAM Voltage || 1.575V
                  PCH Voltage || 1.059V
                  CPU PLL Voltage || 1.794V
                  VTT Voltage || 1.057V
                  VCCSA Voltage || 0.925V
                  DRAM TIMING CONTROL
                  DRAM Freq || DDR3-1066
                  CAS# Latency (tCL) || 7
                  RAS# to CAS# Delay (tRCD) || 7
                  Row Precharge Time (tRP) || 7
                  RAS# Activation (Action? Active?) Time (tRAS) || 20
                  Command Rate (CR) || IN // ... I have what looks like 1N or IN written dwon. Could be 1 V.
                  Write Recovery Time (tWR) || 8
                  Refresh Cycle Time (tRFC) || 86
                  RAS to RAS Delay (tRRD) || 4
                  Write to Read Delay (tWTR) || 4
                  Read to Precharge (tRTP) || 4
                  Four Activate Window (tFAW) || 16
                  Memory Power Down Mode || "Auto"
                  same for:
                  ODT WR (CHA)
                  ODT NOM (CHA)
                  ODT WR (CHB)
                  ODT NOM (CHB)
                    http://www.newegg.com/Product/Produc...D=3067296&SID=
                    ... am I just really stupid and I just need to change
                    DRAM Frequency --> DDR3 1333
                    and then change some of these timings to 9? Not sure which ones, though ... maybe tCL, tRCD, tRP?
                    ... though I'm actually not sure exactly what numbers these reference. e.g., it says voltage 1.5V ... does that mean I should bring it down from 1.575, or is it better to be a bit high?
                    I'm getting hopeful that this situation is fixable.
                      Yes speed to 1333, base timings 9-9-9-24, DRAM voltage 1.5 and CR (Command Rate or Command Timing) to 2T or 2N depending if the mobo uses the T or the N designator
                        http://www.newegg.com/Product/Produc...82E16813157236
                        Is that T or N, do you think?
                        Also: thank you so much. I hope this works.
                        EDIT: It didn't even give a T option, so I did N
                          Yep, it used to always be T w/ Intel system and N with AMD as designators, now it's almost interchangeable - it will be one or the other - Let us know how it goes
