Hello.
I'm about to build a fairly powerful DAW system using the Asus P8P67 Pro motherboard and need 16GB RAM. I'm not sure which G-Skill RAM is best suited. Somebody at overclockers recommended the F3-10666CL9D-8GBRL, or the F3-12800CL9D-8GBRL, or maybe the F3-12800CL9D-8GBXL. But with all these choices I want to be sure what memory is the best supported and easily available in the UK. If 8GB would be more stable, I would settle for that in the short term.
Thanks.
Thanks.
