Hello all.
Hope someone may be able to help me with my problem.
I have the ram in the title installed onto a Asus P6X58D-E motherboard with an
Intel i7 960 cpu. windows 7 64bit.
I would like to increase, poss double my ram, but the problem is that here in Australia suppliers have the same ram as discontinued, a hunt on eBay here and in the US turns up blank.
Do I have any options with a compatible tri set or would I need to use excatly the same ram, either keep looking for NOS or start again?
Thanks for any replies and your time in advance.
Cheers Gavin.
Cheers Gavin.
