Overclocking issues - F3-12800CL8D-8GBXM - P8Z68V-Pro
  • Overclocking issues - F3-12800CL8D-8GBXM - P8Z68V-Pro
    I'm trying to overclock my rig:
    2600K
    P8Z68V-Pro
    F3-12800CL8D-8GBXM
    Corsair H60
    Current settings:
    4.5Ghz (45x)
    Vcore - 1.310
    Memory Freq - 1333 (dropped it down to start)
    VCCIO - Auto
    DRAM Volts - 1.5
    8-8-8-24
    With these settings, I was able to run 24hrs stable using Prime95, temps stay under 70
    But when I try to set the RAM back up to 1600, it keeps getting BSOD.
    I've tried these and it didn't work:
    VCCIO 1.0625, DRAM Volts 1.5
    VCCIO 1.05625, DRAM Volts 1.5125
    I'm getting BSOD 101 errors.
    Any ideas? Thanks.
    If it's hardware, I would lean to the vCore a bit low, might try 1.32, could also be a BIOS bug (from the 101 error), a driver problem, or possibly a program you have i.e. a virus program, basically it's a processor calling to another for and not getting a timely response
      folks on another forum suggested I installed the rams into the wrong slots, so I moved them from A1 and A2, to A2 and B2. I also set it to XMP for now and re-running the test.
