GIGABYTE GA-Z68X-UD3H-B3 motherboard
  • GIGABYTE GA-Z68X-UD3H-B3 motherboard
    I was wondering if the F3-12800CL8D-8GBXM will work in a GIGABYTE GA-Z68X-UD3H-B3 motherboard? I know that these sticks are meant primarily for P67 boards, but if you could suggest some Z68 boards it will work with (if not the one I mentioned,) I'd appreciate it.
    Thanks!
    It will work just fine.
      The Ripjaws X were designed for the P67, but keep in mind the H67 and Z68 are both in the same family (sort of wonder why the Z68 isn't the Z67, prob because it combines the H67 and P67
