Help choosing memory
  • Help choosing memory
    I'm trying to decide between the following 4 kits for an i5-2500k on a Gigabyte GA-Z68A-D3H-B3. Any comments or suggestions would be appreciated... Also, why is the CL8 (last one) cheaper than all the rest??
    Tom
    F3-12800CL9D-8GBSR $77
    http://www.newegg.com/Product/Produc...-416-_-Product
    F3-12800CL9D-8GBRL $85
    http://www.newegg.com/Product/Produc...-314-_-Product
    F3-12800CL9D-8GBXL $84
    http://www.newegg.com/Product/Produc...-428-_-Product
    F3-12800CL8D-8GBXM $75
    http://www.newegg.com/Product/Produc...-445-_-Product
    Good question... it is on promotion ($15 off), so it is actually the best one out of all four, but the cheapest one too. Need help choosing?
      Thanks.... I thought maybe I was missing something in the fine print!
        btw... any idea how long the promo lasts???
          The actual ad says while supplies last, so it may be a short time or if they have a big stock of them, might last a couple of days
            Yea, you always want to get them ASAP, as soon as you see them. G.Skill memory disappears..
            People always tell/complain about how they are shopping.. then when they are finally done choosing all their parts, the item is already out of stock. That's just how it is when you sell good products (5 eggs) at a super low price.
