Hello there, excuse my english, I'm french
I know I'm not the only one having this problem but I tried almost everything I read in other threads but nothing seems to work.
This is my configuration :
As some other members I'm getting blue screen after few minutes and sometimes I need 5 attemps to boot the computer.
I tried the fix I read in the sticky :
Lost all my day trying to fix this problem, nothing worked
So I'm trying to find some help there or I'll just buy some other memory sticks I guess
ASUSTeK Computer INC. M4A79XTD EVO Rev X.0X
Processor
AMD Phenom II X4 945 Deneb Socket AM3 (938) (@45 nm) 3000 Mhz ( L1I: 4 x 64 Ko, L1D: 4 x 64 Ko, L2: 4 x 512 Ko, L3: 6144 Ko )
Memory
2048 Mo, Type: DDR3, @666.6MHz, 9.0-9-9-24-1T
DDR3 G.Skill F3-12800CL9-2GBNQ 2048 Mo PC3-10700 (667 Mhz)
Graphic card :
Radeon HD 5770 (RV840,,1024 Mo)
Processor
Memory
Graphic card :
For DDR3-1600 CL9 kits, you can also attempt DDR3-1333 CL8 (8-8-8-24) 1.50V and this would be just as fast without needing to overclock the system. These are also good settings if you can not get DDR3-1600 to work, and you need fail-proof settings (without overclocking) to test the memory and make sure they are working properly.
