GA-Z68X-UD3H-B3 + G.Skill Ripjaws F3-10666CL7D-8GBRH
  • GA-Z68X-UD3H-B3 + G.Skill Ripjaws F3-10666CL7D-8GBRH
    the Gskill Website says its compatible with
    Gigabyte GA-Z68X-UD3-B3
    but also with
    Gigabyte GA-Z68X-UD3H-B3 ?
    Yep, no problem, the UD3 requires a graphics card is the biggest difference, DRAM is same, same
      ok thank you
        No problem, drop an update on how things come out
