GIGABYTE GA-Z68X-UD3H-B3 and F3-10666CL9D-8GBXL
  • GIGABYTE GA-Z68X-UD3H-B3 and F3-10666CL9D-8GBXL
    The Gskill website shows the memory module (in the title line) is compatible with the
    but does not mention
    GIGABYTE GA-Z68X-UD3H-B3H
    I have the latter version, and I am hoping to rule out my memory modules as a cause of my failure to boot problem (no video and no motherboard beeps).
    Any thoughts?
    Thanks.
    DRAM shouldn't be the problem, unless it's not fully seated, the sticks should be fully compatible. Might check that the CPU is seated correctly, no bent pins in the socket, no thermal compound has seeped under the CPU face or in the socket. Check both 24 and 4/8 pin power connectors to the mobo, graphics card fully seated.....if still problems may want to try a different PSU
      Test one module at a time. If same problem, must be a bad motherboard..
