*CPU:I7-2600K 3.40Mhz
*Motherboard: MSI P67A-GD65
*MEMORY: G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) F3-12800CL8D-8GBXM
*Windows 7
*H70 Water Cooling System.
*Thermaltake 800W Power Supply.
Hi guys.
I'm having some problem with my OC Genie II from MSI, I OC my pc to 4.20Mhz but when i run prime95 my pc will restart it self after 30 minutes or so ruining with prime95.
When i go the BIOS i see the Voltage of my DRAM is 1.666V but my MOBO can only run with 1.5V, After i turn off the OC Genie II and i go to BIOS, I see that my DRAM is sitting again in 1.666V and no back to 1.5V
I contact Intel and they told me the problem is that I7 2600K doesn't support RAM higher then 1333mhz.
I guess what im trying to ask, are this G.skill good for my Motherboard or should i get the 1333mhz that will work better with my CPU and Motherboard?
I apologize for my Engish if the spelling is not correctly.
Thank you.
*Windows 7
Hi guys.
Thank you.
