I am an experienced system builder and I take many precautions when installing new hardware. I built a system back in December with the (2 x 2gb) kit of F3-12800CL6D-4GBPI memory. Although configured for Intel systems, I read reviews it worked great for the AMD X6 processors, so I took a chance. All went well, latencies were as rated and I couldn't be happier.
I decided this past week to order another set to boost the memory to 8gb. So, I'd have 4 x 2gb. I turned off the power, unplugged power cable, and installed the memory in the other two available DRAM slots. I reconnect everything, power up, red DRAM light. I can't boot or see BIOS. I do my test of each stick of memory with each slot. Here is where I run into the problem. Suddenly, NEITHER stick of memory works now, including the ones that worked before.
I heard a possible solution was remove the CMOS. I did that, for about 2 hours.
I used the MemOK! feature to run failsafe settings for all memory sticks in all configurations, still no results.
I am out of ideas except to try new memory and then try new mobo, but I can't believe that all 4 sticks of my memory are incompatible suddenly when the two I bought in December were working fantastically.
Thanks for any help in advance.
