I just recently started building a new computer and am having some problems starting it up. Some of the computer parts are...
Motherboard- http://www.newegg.com/Product/Produc...82E16813131703
CPU- http://www.newegg.com/Product/Produc...82E16819115071
Memory- http://www.newegg.com/Product/Produc...82E16820231451
I got 2 sets of them for a total of 8gb
NVIDIA Geforce GTX 570 HD
1000 Watt Power Supply
The problem i'm having is that after i put everything in and hook it up, when i start my computer it starts up for a few seconds, shuts down, then turns on again, then stays running but nothing shows up on the monitor. All that time the DRAM_LED is lit up. Not really sure if the memory is bad or what's going on at this point. Any suggestions would be much welcomed. Thanks in advance..
P.S I've also tried switching around the memory, putting in less and switching it from slot to slot, and nothing.
