This is my first post, so please go easy on me.
I recently build a system with the title motherboard and RAM, and am unable to get the RAM stable at the spec'ed settings. The most notable issue occurs when trying to wake the PC from sleep mode -- it results in a power loop that requires a CMOS clear.
The RAM is rated @ DDR3-2133 w/ 9-11-9-28. Enabling XMP on the MB, or even setting these specs manually causes the power loop problem.
With that being said, if I run the RAM @ 1600 instead of 2133, I don't seem to have the wake issue. But I obviously expect the RAM to meet manufacturer recommended specs.
I did flash the MB bios to the newest 1.B build hoping it would solve the problem, but to no avail.
Any help / suggestions would be GREATLY appreciated. Thanks!
Edit: I did see the sticky regarding MSI P67 boards, but I am new at this and could use a dumbing down if possible.
