I have random computer crash, I recently add another set of 3 * 2gb G.Skill F3-12800CL9t-6GBNQ to my already existing one, I can say my problem start at the same time, but I think I remember we have to increase the voltage when using 6 sticks of RAM on 1366, the board is a Asus Rampage III gene and the voltage of the memory is set to auto in the bios and it appear to be 1,673 and the timing is 9,9,924 same as the spec of the RAM
SO what is my best option increase a voltage ( witch one0 or simply replace the 6 sticks of 2 gb with 3 of 4 gb and use the stick in others builds
