hello,I got a new computer just 2 months ago.it is:
AMD 955BE
ASROCK 890GX EXTREME3(bios version is the most current P2.5)
F3-12800CL9S-4GBRL
galaxy GTX460 1G SuperOC
CoolerMaster eXtreme Power Plus 500(real output 460W)
it can never run stably, either oced to
cpu frequency multiplier 18.5(3.7G) @1.435
ddr3 1600 9-9-9-24 @1.54v(there is no 1.5v choice,just 1.477v or 1.541v)
or all setted auto
namely cpu3.2G, RAM 1333 9-9-9-24.
I tried set following the sticky thread step by step,however obviously it can not run normaly, beacause the cpu reach 3.8G+.even adapt cpu to 3.6 by decreasing multiplier,it would not work stably.
there are much less problem when i set all bios choices to auto, but it went to blue screens ,no responses sometimes yet.
the blue screen codes mostly like: 3b,0a,7e...
sometimes it can not boot after crash, the debug led on the motherboard mostly says:
D5 Bootblock code is copied from ROM to lower system memory and control is given to it. BIOS now executes out of RAM.
D0 Go to flat mode with 4GB limit and GA20 enabled. Verify the bootblock checksum.
2A Initializes different devices through DIM.See DIM Code Checkpoints section of document for more information.
38 Initializes different devices through DIM.
press the reset more times or trun off the supply and wait for a moment;it will boot.
it crash most when i work with opera, office2007, vs2010 or so.it didn't break down when i play 3d games like F3Secu, dirt3. It go no response serval times, even while i'm setting bios.
what should i do? are there any compatible problems between the ram and the motherboard? or Gskill do not work well with amd platform? Thank you very much. sorry for my poor english...
AMD 955BE
F3-12800CL9S-4GBRL
or all setted auto
