Help setting timings
  • Help setting timings
    Hi
    I've got a problem setting timings.
    My memos are [ Ripjaws-X ] F3-10666CL7D-8GBXH
    I have a Mother Board Intel DH67BL (B3) with i5-2500 processor
    My bios doesn't have XMP option and if I use "automatic" config it puts 9 instead of 7
    So, I have to put manually but I need help to set up the correct timing
    Here is a screenshot of the bios --> http://imageshack.us/photo/my-images/52/gedc0013q.jpg/
    I?ll be very grateful if you could help me
    Start with base timing 7-7-7-21, CR at 2T or 2N (N/T are interchangeable), and DRAM voltage at 1.5 can leave the rest at auto
      But what can I do if I can't leave the rest at auto??? what values should I assign it??
        Which ones do you need?
          I'm asking for
          tRFC
          tRRD
          tWR
          tWTR
          tRTP
          tRC
          tFAW
            tRFC 74
            tRRD 4
            tWR 10
            tWTR 5
            tRTP 5
            tRC 33
            tFAW 20
              Thank you!!
                Let us know how thing go
                  it works good.
                  The problem now is that even though I set the CR configurations to 2T in the bios, other programs such as CPUz and Aida64 show me 1T. However, I believe the problem is with the motherboard now.
                  Thank you for the help
                    In the memory tab or SPD tab? Memory tab should should show as is in the BIOS?
                      My problem is the inconsistency between these two screenshots
                      Bios
                      Programs
                      This is why I am pretty sure the problem is the motherboard
                        Could be a fluke in the BIOS, do you have the latest BIOS? forgot to check when I got back here? If stable, prob not a big prob, might drop Intel tech support a line and ask if they have any input....have seen this happen before but haven't heard of any adverse effects
                          Is it stable? If so, don't worry about it. Either way is fine.
                            Hi
                            I have the latest bios
                            And it's very stable, so I think it will be fine
                            Thanks G.Skill support!!
                              No problem, Enjoy!
