Hi there,
I am working up a new build using an Asrock z68 extreme4 motherboard, an i7-2600K CPU and 16GB of RAM (850W PS, nVidia 570/580 series graphics card, if that matters). Planning to do some overclocking but not trying to reach 5GHz on air!
The question I have is, "which RAM?"
The Asrock website lists only the F3-12800CL9D-8GBSR2 and F3-12800CL7D-8GBXH as compatible memory. The G.SKILL website says that, in addition to the above RAM, several other RAM modules are qualified for the Z68 extreme4, including: the F3-12800CL9D-8GBSR, F3-12800CL9Q-16GBXL, F3-12800CL9Q-16GBRL and F3-12800CL7Q-16GBXH, etc.
G.SKILL's RAM configurator doesn't list Asrock's Z68 motherboards at all.
So my questions are as follows:
1) Will 2 sets of CL9D-8GBSR2's (4x4GB) work or will there be compatibility issues?
Should I go with, presumably, matched 4x4GB modules instead?
2) Same question for the -8GBSR and the CL7D-8GBXH.
3) Some of the modules require 1.65V (the XH series). I've read that the max voltage
spec'd by Intel is something like 1.58V. For reliability sake, should I stick to the 1.25
or 1.5V modules.
4) What is the difference between the RL and XL series? Both are listed as being
compatible with the extreme4 (on G.SKILL's memory list).
Sorry to ask so many questions, just trying to build a system that will fire up/run reliably.
Thanks.
or 1.5V modules.
Thanks.
