F3-12800cl8d-8gbxm at lower setting
  • F3-12800cl8d-8gbxm at lower setting
    Hello all,
    I've searched the threads regarding this model of memory but have not found an answer to my question, which is as follows:
    Can I properly run the G.Skill F3-12800CL8D-8GBXM at 1333 CL7 ?
    I've been told that with AMD processors, the lower CAS ratings are better than higher memory speeds (i.e. DDR3-1333 at CL7 will give me better performance than DDR3-1600 at CL8). Anyone, please correct me if this is wrong.
    Thanks!
    force
    Model of the motherboard: Asus M4A89GTD-PRO/USB3
    Model of the memory: F3-12800CL8D-8GBXM
    Model of the CPU: AMD Phenom II X2 555
    Yes, should be no problem.
      gskill
      Thank you very much!
      Newegg has an *unbelievable* special right on now that model, and I wanted to make sure it would work for my needs.
      Thanks again,
      force
        Let us know how they do for you
          Update
          So far, things are TERRIFIC with the new G.Skill memory!!!
          One question, however, with the F3-12800CL8D-8GBXM at 1333 CL7:
          With this setup, CPU-Z reports the following:
          DRAM Frequency: 668.9 MHz
          FSBRAM 3:10
          CL 7.0
          tRCD 7
          tRP 7
          tRAS 21
          tRC 31
          CR 1T
          Are these values correct, particularly the tRC and CR? I just want to make sure that I have the proper, optimal settings for my RAM.
          Thanks for your time,
          force
            tRC is fine, CR is very good, generally these run at 2T, anytime you can get them at 1T it's a higher performance output (basically only taking 1 clock cycle instead of 2)
              Thanks Tman!!!
              That's exactly what I needed to know.
              Very pleased with Gskill,
              force
                Glad to hear hear it, keep in touch!
