msi h67ma-e45 b3 issue with gskill 10999cl7d-4gbxh
  • msi h67ma-e45 b3 issue with gskill 10999cl7d-4gbxh
    bsod out of nowhere cant boot cant reinstall windows, must pull one stick up to make it back to its working condition.
    Should I enabled the xmp? what else can I do?
    Do you mean 10666? 1333 sticks? Should be able to just install and go. Do you have the latest BIOS?
      yup 10666 sorry fore the typo. Someone told me to boost the dram voltage to 1.55 to 1.60 or adjust the dram timing to 9-9-9-24.
        Timings should be to 7-7-7-21, voltage 1.5 and CR (Command Rate) to 2T....
          I just did what you said. I was running 9-9-9-24 CR-1T which was stable.
          I tried yours to maximize my ram which is stock at 7-7-7-21 1.5 V
            Give a shout how it runs
              Its running for almost a day now, so far so good!
                Sounds good, and while CR at 1T was nice, having the CL @ 7 instead of the 9 is much better performance wise
