When running 12 g.skill ddr3 (f3-12800cl9t) 1600 on a p6t deluxe. The memory defaults to 1033 mhz. To remidy this one must go into bios change the memory from auto (1033) to 1600. We are not done though. This is important!
When doing this the dram voltage defaults up to 1.8v (check turbov) which (according to intel) is too much voltage, it will cause damage to the chip (max 1.5v). To remedy this go into the dram voltage and manualy change it to 1.5v (1.4v)
Now before you reboot you must manually change the qpi/dram in bios to around 1.333. Before i did this my computer wouldn't boot at 1.5v dram. Done!
Now if you test it in prime95 or whatever you will have a stable system running everything the way it should!
