Question about RAM suitability for P8H67-M LE motherboard
  • Question about RAM suitability for P8H67-M LE motherboard
    Hi
    I am building an i5 2500K home office workstation for RAM intensive work (engineering modeling, very large spreadsheets and reports with lots of graphics).
    I have been recommended G.Skill Ripjaws F3-12800CL9D-8GBRL 8GB (2x4GB) DDR3 RAM to go with the Asus P8H67-M LE V3 I have selected.
    However G.Skill's qualified motherboard list (http://www.gskill.com/products.php?index=239) does not list the P8H67-M LE V3 motherboard, so I am unsure if the recommendation is good.
    The ASUS memory Qualified Vendor List for memory (http://www.asus.com/Motherboards/Int...P8H67M_LE/#MSL) does list the 1333 MHz version (G.SKILL F3-10666CL9D-8GBRL 8GB (2x4GB) 9-9-9-24 1.5V RAM) but not the 1600 MHz version.
    Is there a problem with fitting 1600 MHz RAM to this motherboard or is it better to get something that is definitely on the ASUS motherboard QVL?
    They should be fine, the Ripjaws work fine on the H67. The QVL normally consist of what they have had time to test w/ the mobo.
