Is it possible to use 2 packs of F3-12800CL8T-6GBRM in a MoBo Asus P6x58d-e? Is there any special thing I need to do in order to have this memory working allright?
2 x F3-12800CL8T-6GBRM in P6x58d-e
Generally it's best to get all the DRAM you want/might want in a single package to ensure the sticks have all been tested together, but combining sets more often than not will work together....if there is a problem raising voltages slightly will normally be the cure.....however,,,,on occasion one might run into a couple of sets that just won't play together.
