I'm having some troubles with my ram sticks composed of 2 kits of G.Skill Ripjaws X F3-12800CL9D-8GBXL , 2 x 4 GB - DIMM 240-pin - DDR3 - 1600 MHz / PC3-12800 - CL9 - 9-9-9-24 - 1.5 V - unbuffered - non-ECC. http://www.gskill.com/products.php?index=355 So all my 4 RAM slots are used for a total of 16GB of RAM.
I can't make them run at stock speed correctly.
When I first booted my computer, my RAM was detected at 1333MHz. So I loaded the XMP Profile in the BIOS. It switched my RAM frequency to 1600MHz and entered automatically the right timings. But when I rebooted the computer, it wouldn't boot at all. The MemOK red led was switched on, so something was wrong with the RAM settings. I had to push the Mem OK switch to run the Mobo RAM tests. The computer rebooted and I could finally access the BIOS. But the settings were changed and everything in the XMP profile was set to Auto instead of specific values like DDR3-1600MHz, or timings.
For some reason my RAM was running at 1600MHz with the frequency setting set to AUTO (wouldn't boot otherwise, Mem OK red led and so on) but it suddenly switched to 1333MHz, 2 days ago. I reloaded the XMP profile in the bIOS but couldn't the same problems as described before occured:
- the computer won't boot
- the Mem OK red led is switched on
- have to manually push the Mem OK Switch so the mobo sets the RAM with values to its liking
- the mobo switching most of the settings to AUTO
In CPUz I can see the RAM is running at 1600MHz but I'm 100% positive it'll switch again to 1333MHz one day or the other.
We can see the RAM is listed as 10700 (667MHz) ???!!
So how do I do to have my RAM sticks permanently run at 1600MHz ?
Setup:
Intel 2600K
Asus P8P67
SSD OCZ Vertex Turbo
Seasonic 650W 80+ Bronze
Win7 64
Setup:
Intel 2600K
Asus P8P67
Win7 64
