System:
AMD Phenom II X4 965 Black Edition
ASUS M4A89GTD-PRO/USB3
G.Skill F3-10666CL7-2GBRH
Settings:
I started with the default settings and got system lockups in game play. I then moved the CPU/NB voltage to 1.2 and still got lockups. I then changed the DRAM voltage to 1.6, same problems. Next, the timings were set to 8-8-8-24, no luck. I then manually set the NB freq to 2400Mhz, same issues.
Can someone shed some light on the exact settings I should have in my bios for this thing to work?
Settings:
