G-Skill 4GB (2x2GB) DDR3 1600MHz/PC3-12800 Ripjaw Memory Kit CL7(7-8-7-24) 1.65V & As
  • G-Skill 4GB (2x2GB) DDR3 1600MHz/PC3-12800 Ripjaw Memory Kit CL7(7-8-7-24) 1.65V & As
    machine won't boot even to bios
    dram warning led flashing
    is this memory compatible ??
    any help would be much appreciated
    motherboard is Asus M4A88T-M 880G Socket AM3
    process is phenom II 955 black edition
      Should, try initially w/ a single stick and may have to increase CPU/NB voltage....Could you post your BIOS settings
        i can't get a bios screen
          If won't go to BIOS w/ a single stick may see if you can borrow one from elsewhere and try it....if it also fails then may want to check the CPU, make sure there's no thermal compound has seeped into the socket, and that the CPU itself is well seated, ensure the main power and CPU power to the mobo attached, the PSU turned on and plugged in well to both the system and the power outlet, if using a power strip that it also is turned on
