Is GSkill Ripjaws F3-12800CL9D-8GBXL compatible with X58 Motherboard
  • Is GSkill Ripjaws F3-12800CL9D-8GBXL compatible with X58 Motherboard
    I have bought this memory F3-12800CL9D-8GBXL before I noticed that it is specifically designed for Intel Sandybridge CPUs and P67 motherboards, however I've already bought a motherboard for my i7-950 CPU. I don't know if they are compatible...
    The motherboard is ASUS Sabertooth X58 LGA 1366 Intel X58 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
    They are designed primarily for SB but should be fine with your Sabertooth
      Thanks! Then I don't bother to return it and buy a new one...
        Think tou'll be happy w/ both
