My setup is
MB: GA-P35C-DS3R and
RAM: 4GB Gskill memory F2-8000CL5D-4GBPQ,
CPU: Intel Q6600
I run it with settings: 333 (FSB) x 7 = 2.3GHz to get nominal frequency on memory and cpu underclocked.
Memory is set manually to 5-5-5-15,
Refresh to ACT delay is 64, all the rest of timings is Auto.
I needed to set voltage on DDR to +0.7V to get it reporting 2.08V on the health check screen in bios. fsb is upped +0.1V.
Normally PC works ok (it's stable), however a rather strange problem occurs occassionally after resets.
After a reset (some times), when memory gets tested (post screen) PC resets again and comes up with default FSB. Meaning FSB comes back to 266 and memory timings are set to auto. Turning PC off and setting bios back to its working condition doesn't work at this point. I need to leave it for a while before retrying it again.
I cannot find any problem with any of the components, I use Antec's P190 case with 1200W of power supply. So there is definitely enough juice and voltages are stable.
Is there anything you could suggest at this point? I was thinking about giving a try with DDR3.
Would F3-10666CL9D-8GBRL which is 8GB of RAM work with GA-P35C-DS3R motherboard? Has any of you tried running such setup?
CPU: Intel Q6600
