CM Hyper 212 Plus & F3-12800CL6D-4GBPI
  • CM Hyper 212 Plus & F3-12800CL6D-4GBPI
    Hello, i've just updated my pc, i've added another set of F3-12800CL6D-4GBPI, for a total of 8GB, now all the 4 ram slot on my asus P7P55D-E Pro are full.
    I would like to change the retail, cpu cooler from the standard intel, to something like Cooler Master Hyper 212 Plus, but i'm a bit scared about the size of the heatsink, should it fit pretty well or it's gonna cause some trouble with the ram slot
    Can you suggest other good CPU Cooler that will fit good with these ram
    Hopefully a member can offer some input, GSkill should be around come Monday or so
      Any tips ?
      Thanks.
        Consider the Corsair H50 or H70, then you shouldn't have to worry about it.
        ASUS Crosshair V Formula
        Creative SB X-Fi Xtreme Gamer
        Corsair HX850W Modular
        2x Win 7 Home Premium (x64)
          Thermalright CPU coolers will clear any memory. A good option is the Ultra 120 or True Black, those are not huge and do a spectacular job.
