hi there,
im from austria so sry for my english but i try to do my best!
first i?ve installed the memeory at the both blue slots at my mainboard >> can?t enter the bios (no signal)
then i try the two white > same issue.
when i but both memorys to the first slots: one blue and one white everything works fine but just in single channel.(it runs at 1333 CL9-9-9-24 1,5v) Bios v. is F6
can you give me please some help what i can do or set at the memory settings in the bios?
thx
markus
Gigabyte GA-890FXA-UD5 (Bios V.: F6)
AMD Phenom 2 X6 1090T (@3,2ghz)
RipJaws PC3-12800 DDR3-1600 CL9 (F3-12800CL9D-4GBRL)
thx
markus
