I currently have G.SKILL Trident + Turbulence 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 2133 (PC3 17066) Desktop Memory Model F3-17066CL9D-4GBTDSG. I just bought G.SKILL PIS Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 2200 (PC3 17600) Desktop Memory Model F3-17600CL7D-4GBPIS based on G-Skill tech support recomendation as I could not get my original ram anymore. I need to know how to make these both work together in my system. I have an Asus Maximus III Formula with an I5 750, a xfx 5850, and a rosewill extreme 850w power supply. Basically I need to know what settings to use such as voltage and timings. Do I use old ram or new ram settings? Also does the fact that one is pc3 17066 and one is pc3 17600 matter. I tried the XMP profile and it was not stable. System rebooted after about 8 hours of sitting with 3 everquest accounts running at a small load. The physical memory usage was about 55%. This may have been to the cpu as the XMP profile changed its settings also.
The XMP profile set it to:
Target cpu freq 2769mhz
Target dram freq 2135mhz
BCLK freq 213
cpu ratio 13.0
cpu voltage 1.230
dram voltage 1.654
imc voltage 1.35
memory timings 9-9-9-24-2n
these are the current settings still
I do not know much about overclocking so go easy on me please.
BCLK freq 213
cpu ratio 13.0
cpu voltage 1.230
dram voltage 1.654
imc voltage 1.35
