CPU - Phenom II X4 965 125 watt c3 stepping
iv'e been slowly increasing my FSB, increasing voltage for stability and testing for about a week now. im looking to get the most i can out of this ram and have it stable. im thinking it would be faster if i started from the other direction. what would be the highest voltage and loosest timings i should use if im starting out at around 2100Mhz and working my way down? if the cpu runs at around 3.7Ghz at 1.360v would that voltage need to be increased if the fsb is higher but the multiplier is lower(so the freq. is roughly the same)? what is the fastest speed that i can operate ram at in dual channel w/ this cpu and with the 6-core amd? for future upgrades.
