register
what are the best settings with these ram and mainboard my cpu is q6600. I cannot run them in 1333mhz. they run 1066 at the moment anything I do locks my computer
What do you have the Q6600 at? I ask, because you'll need a decent OC to get up around 1333 on the sticks. With a decent aftermarket cooler you can easily run 3-3.6 GHz with Q6600. Regardless, should run 3GHz w/stock cooler and the sticks about 1200 if not up to 1333.
+10 should be within operating system range. If worried could try new application of AS (Artic Silver or other thermal compound....or a new cooler, with the Q the Zalmon 9500 or the Artic cooling Freezer 7 Pro are good choices, have used both on the 6600's w/ no problem
Thanks to everyone I have used thermal grease on the cpu with my cnps7700 and I get better results now the temp goes no higher than 50 C.
Thanks again for all your help
