I have set my RAM to:
9-9-9-24
1.6v
Memeory Clock 8x
But what of the other settings available, which are at stock:
Ganged or unganged
Tt/2T Command Timing
TwTr Command Timing
Trfc0 for DIMM1
Trfc2 for DIMM2
WRite Recovery
Precharge Time
Row Cycle Time
RAS to CAS Delay
Bank interleaving
CHannel interleave
DQS Trainng Control
Memlock tristating
I also have a ASUS M4A78LT-M LE AMD 760G (SOCKET AM3) MOTHERBOARD, could this be a better choice than the Giagbyte?
My system:
AMD Phenom x2 555 BE (stock)
Gigabyte GA-880GM-D2H Rev 1.2 with latest BIOS
F3-12800CL9D-8GBRL
Radeon HD 5570 DDR3 1024MB 650MHz PCI-E
ARCTIC COOLING FREEZER 7 PRO REV 2 CPU COOLER
I plan to overclock the CPU but want to get the memory right first.
9-9-9-24
1.6v
Memeory Clock 8x
Ganged or unganged
TwTr Command Timing
Trfc0 for DIMM1
Trfc2 for DIMM2
WRite Recovery
Precharge Time
Row Cycle Time
RAS to CAS Delay
Bank interleaving
CHannel interleave
DQS Trainng Control
Memlock tristating
My system:
F3-12800CL9D-8GBRL
