Hey all,
I am having some blue screen issues on a newly built pc. Ive been at work all day, researching scenarios & problem solving.
First things first, I will run each ram card with memtest.
My question is if the ram comes out okay.....I dont want to flash the bios just yet.
What are the correct values I should tweak in my bios. All I really know for sure is to make sure the volts are set to 1.5v. as for everything else, Id really appreciate a list of parameters.
heres my original thread in tomshardware
Hey all, been lurking all afternoon looking for answers. Heres my setup (2 days old)
cpu-intel i5 760 lynnfield
mb-GA-P55-UD3
vga-evga GTX 460 superclocked(factory oc
ram-g.skill ripjaws DDR3 dual channel 1600 2gig x 4 (8gigs)
psu-OCZ fatality 550w
hdd- sata seagate barracuda 80/ sata seagate barracuda 160 (8500rpm??)
cd- 2 nec dvd burners ide - primary & slave
Everything is new, except for the case & 2 sata hdd's. I didnt format the hard drives from a dos/bios based utility. I cleared them within the windows install. It seemed to do it rather quickly, and kept the partitions, but they were cleared. One other thing I did was I used my old video card (evga 6660gt) during the install, because my 460 GTX was still coming in the mail. I didnt install any video drivers, just used it as a basic video output, since there is no on-board video with the ga-p55-ud3.
Windows installed with no problems. I was able get into windows with no problems. But within the first 10 minutes of windows running, while I was installing drivers & utilities from the gigabyte cd, it crashed with a blue screen. I restarted, and it was stable enough for me to finish installing & updating drivers. Then I installed Avast! internet security, no problems. Downloaded windows updates, with a few restarts in-between, no problems.
Put in the new video card last night, and installed newest drivers. Computer worked great, and I was able to explore win 7, internet, tested out some hd video files to see the performance of the new video card. everything worked great. I tried to turn on the pc this morning, and once I get past the Windows password screen, it goes to blue/freeze & restarts. Upon restart, it froze again after the password screen. I just turned off the pc & went to work. I was having trouble last night with sound, and was tinkering around with sound settings, & downloaded the newest realtek hd sound driver from the GB website. It fixed my sound, sort of.....i think I have my front panel connectors installed wrong.
Long story short:
This started happening on an EMPTY windows install with nothing else on the hdd. That is why I am asking here, instead of trying to figure out a software issue. Could it be the hdd's? They arent on a RAID setup. Could it be the fact that I used my old video card during the install? I read another post about someone having issues with the gskill ram. Everything is recognized in device manager & everything seemed to be operating when I looked at the MB diagnostics.
the only 3-rd party software on this computer is : gigabyte utilities, avast internet security & firefox.
mb-GA-P55-UD3
Long story short:
