I have two kit of F3-10600CL8D-4GBHK, my mobo is a MSI 785GM-E65 and my processor a athlon II 610e revicion C3. I test separaly each of the four memory modules with integrated windows 7 memory test utility with this timing: 8-8-8-1T at 1333Mhz (all the others timings parameters are set to auto) and voltage set to 1.5v
I have a strange problem with only one of the four modules.
I dn't know if the memory test fail with this module because at the end of the test windows 7 freeze during loading or a very few minutes after it's completion.
I reboot the computer and I get the same problem. In fact each time I use this module, and only with this, my computer freeze during the loading of windows 7 or just a few minutes after completion.
I try with timings set to 9-9-9-2T and voltage set to 1.6v but no change.
I test the module at 8-8-8-1T 1.5v with memtest86+ (4 pass) and I get no memory error.
I try to change other setting in my BIOS to see if they change something... if I disable Memory Power down, my computer don't freeze (at 1333Mhz), same thing if I lower the memory speed to 1066Mhz and keep memory power down enable (mode is set to channel).
What do you think of this ?
